Cadence Data dropping.
Kcblair
Post by Kcblair »
Hello John,
Noticed on my last 2 rides, the cadence data is missing in several parts of the ride, like i was coasting, but in Garmin Connect, it's all complete. I use the same sensor on all bikes. Battery is fresh.
Thanks, Ken B.
iBike_07_16_2024_0650_19_Miles_Concorde _HiDef.ibr
(968.25 KiB) Downloaded 594 times
iBike_07_26_2024_0901_18_Miles_Raleigh CC_HiDef.ibr
(878.23 KiB) Downloaded 595 times
iBike_08_01_2024_0653_17_Miles_Raleigh CC_HiDef.ibr
(840.53 KiB) Downloaded 634 times
Re: Cadence Data dropping.
I would reset your cadence sensor (remove battery, insert backwards for 1 second, then reinstall properly), and also do a hard reset of your PP (press-hold button for about 12 seconds. Release button after light goes out momentarily, then starts blinking).
After PP reset you'll need to reset time by connecting your device to VA or Isaac.
It is likely that the cadence battery is getting low. Replace it. A new battery will measure around 3.3V and when the voltage gets below 3.0, the PP sometimes starts losing the signal.
The Garmin may still show all is well, but the PP will show dropouts or not even find the sensor at all.
Kcblair
Post by Kcblair »
Velocomp wrote: Thu Aug 01, 2024 3:01 pm I would reset your cadence sensor (remove battery, insert backwards for 1 second, then reinstall properly), and also do a hard reset of your PP (press-hold button for about 12 seconds. Release button after light goes out momentarily, then starts blinking).
Thanks John, done.
Kcblair
Post by Kcblair »
lorduintah wrote: Thu Aug 01, 2024 4:43 pm It is likely that the cadence battery is getting low. Replace it. A new battery will measure around 3.3V and when the voltage gets below 3.0, the PP sometimes starts losing the signal.
Hello Tom,
Battery had 3.01 v. I installed new battery.
Kcblair wrote: Thu Aug 01, 2024 5:16 pm
Hello Tom,
Try a cadence sensor reset: remove battery, install backwards for 1 second, remove and reinsert correctly.
