Velocomp Aero software for Windows
We recommend installing Velocomp Aero software for all AeroPod and PowerPod customers.
Here is where you can get the new Velocomp Aero (VA) for Windows software. This links you to the installer.
NOTE: VELOCOMP AERO FOR WINDOWS REQUIRES WINDOWS 10 OR 11 OPERATING SYSTEM. IT WILL NOT WORK WITH EARLIER VERSIONS OF WINDOWS.
https://github.com/velocomp-llc/AeroRel ... -Setup.exe
After installing Velocomp Aero for Windows, any subsequent updates will happen automatically through the VA app.
ALSO: if you have never used Isaac software before, you will also need to install Silicon Labs drivers, attached. NOTE: IF ISAAC IS WORKING ON YOUR PC, YOU MAY STILL HAVE TO INSTALL THE UPDATED SILABS DRIVERS LINKED BELOW IF VA DOES NOT "SEE" THE USB CONNECTION.
CP210x_Windows_Drivers.zip
(6.87 MiB) Downloaded 131 times
When installing the SiLabs drivers, click on the "CP210xVCPInstaller_x64.exe" file to start the installation. Before completing the installation make sure to click on "Extract All" before proceeding with the install.
Here is where you can get instructions regarding how to install and use the VA software:
https://velocompforum.com/viewtopic.php?f=106&t=6032
Jesper
Re: Velocomp Aero software for Windows
Post by Jesper »
A note on the SILABS driver: I actually had to install the SILABS driver before Velocomp Aero was able to see my AeroPod - even though it was working fine from Isaac.
Jesper wrote: Sun Jun 16, 2024 4:14 pm A note on the SILABS driver: I actually had to install the SILABS driver before Velocomp Aero was able to see my AeroPod - even though it was working fine from Isaac.
Thanks for the update...it may be that SiLabs has updated their driver from the version you had with Isaac.
Return to “Velocomp Aero Software for Mac/PC”
