I have transferred a ride from my Powerpod to Isaac and deleted the file from Powerpod.
I then added gps data by merging gps and other data (using a gpx file) and saved the resultant file.
I've now realised the merge gpx file didn't include the first few miles of the ride so I want to revert to the original Ibike file but Return To Original Download doesn't remove the merged data.
Is there a way to do this once the merged date file has been saved?
Restore original downloded file
- lorduintah
Re: Restore original downloded file
Check the computer directory where your ride files are stored - there may very well be an original version there that you can star over with,
The ibr file saved on my pc is the updated version, following the addition of GPS date from my Garmin computer.
I've tried using Analyse/Return To Original Download but it doesn't work. Is this because I saved the updated file?
Is there a way to Return To The Original Download once updates/amendments have been saved?
I have attached the file in case anyone has any suggestions.
- Velocomp_05_02_2024_1026_26_Miles.ibr
- (600.81 KiB) Downloaded 573 times
If I understand you correctly, you'd like to merge again a GPX file (though the second GPX file may be different from the first which is already part of the .ibr ride file).flysplat wrote: ↑Tue May 07, 2024 10:24 am The ibr file saved on my pc is the updated version, following the addition of GPS date from my Garmin computer.
I suggest trying another "File/Merge GPS File..."
Alternatively, if you're saying that, for some reason, the first few miles of your .ibr file have been lost, and you've erased your PP, I'm afraid there is no way to recover the missing portion of the .ibr file.
Note that if you recorded your ride on your Garmin, then the .FIT file likely includes the entire ride.
