PPV4 always wind in the back!
meste
Post by meste »
Something strange started to happen to my otherwise reliable PPV4. It started a week ago when I had trouble connecting it, in the process I had to remove the ANT+ connection from my Garmin 550 and since that, no matter what I do, I can only connect the pod through BT. Tried finding the pod on my Garmin watch, but again, only can find the BT.
Secondly, today in my 50k run which consisted of going out and back in two places, I could see on my device screen that the wind was always from the back! Home I downloaded the ride and yes, the wind is always from the back which is strange (I have attached the ride). Also in some occasions the power went very low like it was trying to calibrate for 10 sec then restoring to normal numbers.
Could you check the ride, maybe there is a setting wrong on my device.
Meste
Velocomp_04_13_2024_0851_33_Miles.ibr
(318.75 KiB) Downloaded 279 times
meste
Re: PPV4 always wind in the back!
Post by meste »
I see that Speedyg had a similar issue which was sorted out by you.
Your wind scaling factor is wrong.
Corrected profile and ride file are attached.
mesteVelocomp_04_13_2024_0851_33_Miles.ibr
(490.07 KiB) Downloaded 284 times
Meste.ibp
(561 Bytes) Downloaded 268 times
meste
Post by meste »
Thanks John, I will use this profile.
I am a little curious of why such thing happened... Let me explain: for the same bike and unit I got a profile corrected from you some time ago and the wind correction on that one is 1.212, compared to what you corrected yesterday which is 2.963 I find it quite very big difference. I wonder what could have caused such a change?
Fric is another huge difference between the old (11.158) and new profile (-69.790). Could this be from mounting the pod on different angles?
I do not claim I understand some of this numbers implications, but I willing to learn more, maybe in order to adjust in the future and adjust the parameters by myself.
I did a nice OAB calibration this morning, after which the ride (w/o your corrected profile) was better than the yesterday one but still on going behind wind - I have attached it - maybe you can teach me how to correct / adjust it myself - many thanks
OUB cal 14Apr24.ibp
(499 Bytes) Downloaded 312 times
Meste
meste
Post by meste »
UPS! Trying to upload your corrected profile to my unit I got an error Fric and riding tilt out of range! So cannot use it.
Screenshot 2024-04-14 at 11.29.04.png (66.86 KiB) Viewed 9589 times
This message means your unit has been moved and is significantly out of calibration.
Please do a new cal ride, then post a ride file afterwards.
meste
Post by meste »
See attached as requested.
Velocomp_04_14_2024_0749_39_km.ibr
(385.7 KiB) Downloaded 286 times
OUB cal 14Apr24.ibp
(499 Bytes) Downloaded 260 times
Your ride file looks really good, but I tweaked your profile a bit!
Please load this into your unit.
Meste_corr.ibp
(568 Bytes) Downloaded 284 times
meste
Post by meste »
Thanks John,
I will give it a go and see how it goes.
