No PowerStroke today
The file from 8-04 is not showing the PowerStroke result yet the file was recorded as a HiDef file - I have been recording all my rides this way. The file date 8-03 does provide the PS results.
I get a dialog that tells me to go to iBike to learn about this feature.
I check the device keys and PS is there for this device.
Seems like something has been corrupted.
Velocomp_08_03_2023_1150_12_Miles_HiDef.ibr
(667.82 KiB) Downloaded 389 times
Velocomp_08_04_2023_1339_7_Miles_HiDef.ibr
(433.09 KiB) Downloaded 411 times
Re: No PowerStroke today
Cadence data is missing from your 8/4 file; this is why you have no PS information.
I don't know why your cadence data is missing, but I suggest a battery replacement for your cadence sensor, and a hard reset for your unit.
Yep - saw that a few minutes after I posted this. I recently replaced the battery - but will do that again.
Will then replace the critical values on the new profile to get back to the good set that I have had.
Speedyg
Post by Speedyg »
I am also getting no power stroke data despite having upgraded PP to Powerstroke.
Here's the data from Unlock status:
Screen Shot 2023-10-02 at 4.19.30 PM.png (20.01 KiB) Viewed 8795 times
And here's today's ride file (after doing the PStroke unlock last night
Velocomp_10_02_2023_1520_13_Miles.ibr
(146.04 KiB) Downloaded 396 times
What's my best course of action to get Stroke working.
I had it once but downgraded the unit because it was filling memory too quickly. Now would like to use it again.
Best,
Jim
Speedyg wrote: Mon Oct 02, 2023 4:25 pm I am also getting no power stroke data despite having upgraded PP to Powerstroke.
Best,
Jim
It sounds like PS may have been turned off.
Go to Device/Setup/Set Sample rate:
Screen Shot 2023-10-02 at 9.48.25 PM.png (243.47 KiB) Viewed 8782 times
Make sure PS is checked.
Screen Shot 2023-10-02 at 9.48.11 PM.png (47.33 KiB) Viewed 8782 times
If not check the PowerStroke box, then things should work afterwards.
Speedyg
Post by Speedyg »
Thanks so much. Will try next ride.
Jim
