PowerPod V3 problem windsensor
PaulK32
Post by PaulK32 »
Good Afternoon John,
Can you help me with your analyse and advice ?
I have the situation that I am not able to make a file on the PowerPod with a O&B ride. It always go to 50 and 100 but then shows 4 seconds "thrue values" and goes in O&B mode again. I tried a lot and I could not get it work. I used it by pusing via Isaac a profile in the PowerPod, knowing that it uses 90 seconds to "fine tune".
An extra problem came after 01-04-2023. My PowerPod V3 with Pitot Tube gives no wind-data (again). I send it in Q4 2022 and now I have the problem again. Can you give a look on the attached files.
01-04-2023 MTB ride. Isaac shows after 25 minutes a change in the wind values. As if there is only rear wind. Power-values came on the Garmin as "normal".
02-04-2023 MTB ride. No wind-values; also 0.0 shown on the Garmin (Aeropod app).
Today (15-04-2023) I did several attempts to get a result (profile) from O&B rides. No result, and also no wind-values.
I also used a PPV3 from a bike-friend. It workes for a O&B ride and profile wind-values included.
Hope you can help.
With kind Regards
Paul
The Netherlands
PB_2023_04_02_0920_49_km_HiDef.ibr
(1.39 MiB) Downloaded 213 times
(1.39 MiB) Downloaded 235 times
PB_2023_04_15_1201_1_km_HiDef.ibr
(58.47 KiB) Downloaded 241 times
Re: PowerPod V3 problem windsensor
Please post the 01-04-2023 file. You posted the 02-04 file twice.
PaulK32
Post by PaulK32 »
Sorry, I tried to attach 4 files. That did not work on my PC. So here is the 01-04-2023 file.
With kind Regards,
Paul
PB_2023_04_01_0844_52_km_HiDef.ibr
(1.74 MiB) Downloaded 197 times
Something appears to be wrong with your wind sensor. Please email technicalsupport@velocomp.com for next steps.
