John hi,
I'm using V3 for quite some time, and I'm pretty happy with it. Recently, I changed the bike, made some tweaking on my profile, and did the calibration ride. Everything went well, but afterwards I had noticed low reading on my power output.
I did a test ride against my Assioma Duo, and my suspicions was confirmed. Powerpod readings are some 20% lover then my Assioma's.
Could you be so kind, and take a look on my ibr and tcx files of the same ride, and tweak my profile so they match?
Thank you very much!
BR,
Dalibor
Power Pod V3 Low reading
- iBike_02_11_2023_1305_24_km.ibr
- (225.01 KiB) Downloaded 184 times
- Infinito 2023.ibp
- (503 Bytes) Downloaded 167 times
- activity_10488777079 (1).tcx
- (2.66 MiB) Downloaded 172 times
Re: Power Pod V3 Low reading
Here is what I did:
1) I merged your .tcx file into your PP file. This merges your Assioma data into your PP ride file
2) I used the command "Check Calibration" to check the DFPM data against your ride file
3) I used the DFPM data to adjust your profile
4). This change improved your wind scaling and increased your watts
Corrected ride file and profile are attached
- Dalibor.ibp
- (635 Bytes) Downloaded 162 times
- Dalibor_Corr_02_11_2023_1305_24_km.ibr
- (415.11 KiB) Downloaded 212 times
John hi,
thx for the instructions & corrections to the profile!
Br,
Dalibor
Br,
Dalibor
