I have a Bkool Smart trainer that doesn't appear to be supported by Powerpod.
Can a file generated by Bkool such as gpx/fit or csv be imported into Isaac so that I can delve into the greater analysis provided by Isaac?
Import Smart Trainer gpx/fit/csv file.
Re: Import Smart Trainer gpx/fit/csv file.
I'm not sure what you want to merge...
If your trainer can export a gpx file, then the gpx file can be merged into Isaac with this command. But, I don't know what info your gpx file has, and if that data will be read by Isaac.
- Screenshot 2022-11-18 at 4.18.11 AM.png (215.32 KiB) Viewed 28566 times
What I want to do is view data from a gpx/fit or tcx file that has been created by the smart trainer in Isaac as a new ride so that I can view it in the same format as a "Powerpod" ride with the same graphs and data analysis.
I'm guesing the files, whilst having the same file extension such as gpx, tcx or fit probably aren't compaitible with Isaac.
I know how to merge data, say from my Garmin, so that I can see the route under the GPS tab.
The only way to import gpx data into Isaac would be by recording a PP file, with a speed sensor on your trainer bike and PP paired to it. I have no idea what data, if any, Isaac would accept from your trainer.flysplat wrote: ↑Fri Nov 18, 2022 7:21 am Hi John,
