macOS Ventura; yes, Intel Isaac/Mac works!
October 10, 2023: See this post for the latest information regarding Isaac/Mac
https://velocompforum.com/viewtopic.php?f=35&t=5989
Apple has released macOS 13, Ventura.
We previously confirmed that Isaac/Mac is compatible with Intel Macs running macOS 12.x and prior.
Assuming that you have an Intel with Isaac/Mac working with macOS 12.x, we have confirmed that macOS 13 will work with Isaac/Mac.
We have also confirmed that Parallels 18.x will work with Isaac/Windows running on Parallels.
This is good news!
GuidoDH
Re: macOS Ventura; yes, Intel Isaac/Mac works!
Post by GuidoDH »
I recently switched from an Intel MacBook pro to a MacBook Pro M1 MAX, on the Intel one I installed ISAAC using VMware and an old copy of OSX Catalina and everything still works fine, can I do the same thing on the M1 MAX? That is, installing VMware with the old copy of OSX Catalina and then installing ISAAC and its drivers from scratch? Has someone already done it?
GuidoDH wrote: Tue Feb 07, 2023 11:55 am I recently switched from an Intel MacBook pro to a MacBook Pro M1 MAX, on the Intel one I installed ISAAC using VMware and an old copy of OSX Catalina and everything still works fine, can I do the same thing on the M1 MAX? That is, installing VMware with the old copy of OSX Catalina and then installing ISAAC and its drivers from scratch? Has someone already done it?
We have tried getting the M1 to work with a VM and, unfortunately, we have not been successful.
We HAVE had success getting Isaac to work with the M1, following this approach:
http://www.velocompforum.com/viewtopic.php?f=35&t=5868
GuidoDH
Post by GuidoDH »
Thanks works fine! Superb tutorial... I'm afraid that doesn't exist an OSX Apple silicon working version of ISaac...
GuidoDH wrote: Tue Feb 14, 2023 2:50 am Thanks works fine! Superb tutorial... I'm afraid that doesn't exist an OSX Apple silicon working version of ISaac...
AS OF 10/2/23 WE HAVE ISAAC/MAC WORKING ON M1/M2 MACS AND ALSO Intel Macs. FOR INSTALLATION INSTRUCTIONS GO HERE:
