V3 Firmware v9
luxmoggy
V3 Firmware v9
Post by luxmoggy »
Hello,
So I created the VM on my Macbook so I could connect to the PowerPod. I upgraded the firmware and did a reset. I knew I should do a new calibration ride (new heart rate sensor, new wheels, removing the magnet speed sensor and my weight).
So I did a calibration ride. I didn't know that I had to change the set-up to save the file for that ride. In the end, I continued to ride.
Attached is the file from today's ride:
Velocomp_08_01_2022_1505_8_Miles_HiDef.ibr
(310.62 KiB) Downloaded 259 times
Here is the original Calibration ride from 2 years ago
Velocomp_05_22_2020_1433_2_km_CalRide.ibr
(28.55 KiB) Downloaded 228 times
I think that they match well enough given the changes to my bike and me. But I would be happy for you to look at the files to see if you agree.
This week I will tackle the long hill where I have to go slow, which is one of the changes in the firmware, that I no longer need the double magnet sensor.
Re: V3 Firmware v9
Everything looks fine in your 8/1 file. Let us know how the hill climb goes!
luxmoggy
Re: V3 Firmware v9
Post by luxmoggy »
So have just climbed the hill. I have power numbers all of the way up - of course none on the downs. I will download the ride later.
The Garmin average Power the options are with or without 0.
Which is a the best choice?
luxmoggy
Re: V3 Firmware v9
Post by luxmoggy »
Here is the ride file. It all looks good even on the slow climb.
Velocomp_2022_08_03_0812_7_km_HiDef.ibr
(362.66 KiB) Downloaded 314 times
Re: V3 Firmware v9
luxmoggy wrote: Wed Aug 03, 2022 3:15 am So have just climbed the hill. I have power numbers all of the way up - of course none on the downs. I will download the ride later.
Ride file looks fine.
For power averaging I use "with 0". This more clearly reflects the energy your body expended during the ride.
