Recent Cal Check
Recent Cal Check
John -
I think this is a reasonable file to inspect for Calibration Check. The adjusted values look OK to me. There were a few changes from the initial cal ride but I do not think any drastic alterations took place.
iBike_06_10_2022_1200_7_Miles_HiDef.ibr
(315.23 KiB) Downloaded 219 times
Re: Recent Cal Check
Hmm...
Crr is high...MTB territory. If this is a road bike it should be around 0.0054
Wind settings look great.
John -
The wheel set is set for gravel - but most riding is on decent asphalt. Roval - SLX-24, Specialized 30-32mm Tires at about 40 PSI. Which probably does raise the Car from normal road values.
lorduintah wrote: Sat Jun 11, 2022 9:09 am John -
If so then all is well... :-)
