AeroPod battery charge level
Good morning, I have an AP with firmware 9.0 and I was wondering if it is possible to see the charge status somehow (Edge, App, Smartphone ...) maybe before going out for a ride
Re: AeroPod battery charge level
On your Garmin go into setup and find your PP sensor. You'll see battery status in the sensor information.
I was wondering if it was possible to implement this data in the dedicated page, for example as on the Varia...
I don't see the battery charge on this page, am I doing something wrong?
- IMG_20220305_190832.jpg (106.59 KiB) Viewed 14998 times
virtualdynamo
You say you have FW 9.00, but your GPS indicates 1.3. Resolve that problem and I predict the battery level will be rectified.
- Screenshot 2022-03-06 212900.jpg (32.51 KiB) Viewed 14957 times
Today I double check better, I would not have the wrong sensor, when I connect AP to ISAAC, it tells me that I am at version 9.0
virtualdynamo
Prossimo dimmi nell'italiano anche, per favore. Forse te capirò meglio.
Ho collegato AeroPod al mio Edge 830, la risposta è come nella foto del mio post, collegando AeroPod al PC, il software mi dice che non ci sono aggiornamenti....
virtualdynamo
Qual è il versione software del tuo 830? Il versione vegente è 9.10.
What is the software version of your 830? The current version is 9.10.
- 48.jpg (10.64 KiB) Viewed 14771 times
stavrosd2006
Garmin Fenix 6 series, used as head unit.
Checked under sensors &accessories ,my aeropod is found as powerpod,when unit is connected to Fenix, about tab is activated and I can select it,
A lot of info is shown,
However next to battery I get :invalid, does that means I cannot see battery level?
Above it, is software version :1.3. Is this aeropod software? My aeropod has latest software installed.
Thank you
Stavros
Thank you
Stavros
Confermo il firmware del mio 830 è v9.10, proverò a installare il nuovo firmware dell AP v.9.01, vi aggiornerò.virtualdynamo wrote: ↑Tue Mar 15, 2022 7:54 am Qual è il versione software del tuo 830? Il versione vegente è 9.10.
Allego foto dell'aggiornamento... le indicazioni della batteria non ci sono
- IMG_20220326_124708.jpg (146.51 KiB) Viewed 14495 times
stavrosd2006
Finally figured this out for Garmin Fenix 6 series : there are two power pods found when pairing with Fenix, it is the second one called PWR-550 that has both battery and latest software installed informations.(ANT+) tech.stavrosd2006 wrote: ↑Sun Mar 20, 2022 8:55 am Garmin Fenix 6 series, used as head unit.
Thank you
Stavros
By the way, for the aforementioned watch there is also PWR-Powerpod found during pairing ,(BLE) tech, and does not contain battery status info.
