Does PowerPod require a new calibration ride after battery is completely drained?
ning
Post by ning »
I ran into this a few times now. Since I did most of my outdoor rides over the weekends, I often forget to charge the powerpod and days later the battery is drained when I tried to ride. However after charging and turning it on, the powerpod jumped into the calibration ride mode directly, which is quite annoying. Is this the expected behavior or did I do something wrong?
Re: Does PowerPod require a new calibration ride after battery is completely drained?
No, PP does not automatically go into cal mode when the battery is charged.
PP goes into cal ride mode when its button is press-held for 4 seconds.
When you turn the unit on, click the button and release it immediately.
