Wind and slope stop reporting but power ok
Wobblydrow
Just did a big 250km ride, after 60km we stopped for coffee and I turned my PP and garmin off. After I reconnected and power was ok, but after ride, wind and slope were a flat line, any ideas why that might be
Re: Wind and slope stop reporting but power ok
Please post .ibr ride file.Wobblydrow wrote: ↑Mon Dec 27, 2021 3:34 am Just did a big 250km ride, after 60km we stopped for coffee and I turned my PP and garmin off. After I reconnected and power was ok, but after ride, wind and slope were a flat line, any ideas why that might be
Wobblydrow
When i downloaded the files for the ride into Isaac, it appears that as i stopped the PP to save battery life during the ride, it saved all the rides as seperate files, however, my garmin only recorded the power once the second part of the ride commenced. This is interesting as the wind on the garmin widget works the first part of the ride, but from the second part does not pick the signal up again, or the slope, but does continue to see power.Why might the garmin only see part of the data signal upon reconnecting to the PP? I dont get this if i turn the garmin off, e.g. on a commute before and after work, it only appears to happen if PP is off and garmin set to stop , then reconnected and started again
Here is the first and second parts of the ride, part 1 garmin all ok, part two only power reported, but all ok in isaac
- 12_27_2021_0546_37_km.ibr
- (371.26 KiB) Downloaded 225 times
- 12_27_2021_0744_121_km.ibr
- (1.21 MiB) Downloaded 239 times
There are mysterious things in Garmin communications that we do not understand. You have stumbled across one of them.Wobblydrow wrote: ↑Wed Dec 29, 2021 8:00 pm When i downloaded the files for the ride into Isaac, it appears that as i stopped the PP to save battery life during the ride, it saved all the rides as seperate files, however, my garmin only recorded the power once the second part of the ride commenced. This is interesting as the wind on the garmin widget works the first part of the ride, but from the second part does not pick the signal up again, or the slope, but does continue to see power.Why might the garmin only see part of the data signal upon reconnecting to the PP? I dont get this if i turn the garmin off, e.g. on a commute before and after work, it only appears to happen if PP is off and garmin set to stop , then reconnected and started again
It appears that, after stopping, the ConnectIQ app did not "reconnect" with slope and wind channel. Why this happened I do not know. To avoid this situation in the future you might want to power off the Garmin during your breaks, then restart everything afresh when you resume riding.
