Power too high? Part 2
Here come the files for the 2nd bike.
- Planet X 15 Oct 2021.ibp
- (364 Bytes) Downloaded 266 times
- Planet_X_PPv4__23_11_2021_1712_22_km_HiDef.ibr
- (573.66 KiB) Downloaded 277 times
Re: Power too high? Part 2
Your profiles were "off". Planet X had too high wind; De Rosa, not enough.
Both are adjusted and now are very close to each other.
Load profiles into bike and you should be all set.
- Planet_X_JRH_PPv4__23_11_2021_1712_22_km_HiDef.ibr
- (507.01 KiB) Downloaded 279 times
- De_Rosa_JRH_PPv4__08_11_2021_1544_22_km_HiDef.ibr
- (463.81 KiB) Downloaded 267 times
- PlanetX JRH.ibp
- (368 Bytes) Downloaded 284 times
- DeRosa JRH.ibp
- (499 Bytes) Downloaded 291 times
Brilliant. Thank you so much John. I also just switched profile on my latest FTP ride and all of a sudden my FTP increased by 16% from 234 to 272 - wonderful
How do you recognise such wrong settings? Just your years of experience or are there some golden rules or tips to follow?
I look at the bike/wind speed window. If I see constant tailwinds (DeRosa) or constant headwinds (PlanetX) I know something is amiss. I adjust the profile so that wind speed is approximately equal to bike speed.albafar wrote: ↑Fri Nov 26, 2021 11:35 am Brilliant. Thank you so much John. I also just switched profile on my latest FTP ride and all of a sudden my FTP increased by 16% from 234 to 272 - wonderfulHow do you recognise such wrong settings? Just your years of experience or are there some golden rules or tips to follow?
Ah - get it. But then we might have an issue. As this were commute rides - primarily in one direction (NW) and wind coming from W more or less (at least for the Planet X ride).
I think I better do an o&b ride this weekend and see how the Check calibration results look.
OKalbafar wrote: ↑Fri Nov 26, 2021 1:25 pm Ah - get it. But then we might have an issue. As this were commute rides - primarily in one direction (NW) and wind coming from W more or less (at least for the Planet X ride).
