Gear selection indicator
11Rudgunasflyer
Post by 11Rudgunasflyer »
I attempting to re-sync my powerpod to my Wahooo Roam.
Each time I do the powerpod shows up as a 'Gear Selection Indicator.' Anyone else had this difficulty.
I am re-syncing because the power pod stopped communication. I selected forget the device to start over. This didn't work the way I anticipated.
Repectfully,
Jesse
Re: Gear selection indicator
Hmm...Wahoo should see this as a power meter.
You might want to reboot your Wahoo and try again. If that doesn't work you should contact Wahoo tech support.
PowerPod is ANT+ certified, so don't let them give you any excuse that it isn't their problem.
