PowerStroke
TdeCampo
PowerStroke
Post by TdeCampo »
Here a complement and a question:
1. Complement. PS has been an excellent tool to improve my pedaling I have always concentrate in smooth pedaling but nothing better than numbers and graphics. The followings pic are 1. PS 2017 was the first time I use it. 2. 2019 I started to focus in the PS information and trying to change the vector forces more perpendicular and decrease the wasted force applied to the pedal and the result is obvious 3. The last pic is from yesterday and creates the question:
2. Question: SP show a perfect pedaling technique that I wonder if it is real or that VeloComp has decided to be more "tolerant" so more users look better?. The graphic imho provides the best info to analyze and improve your pedaling The present graphic is so small is worthless. These changes are new. I hope Velocomp goes back to the previous setup.
This is a great tool tool, Velocomp deserve kudos +++
-=terry=-
Re: PowerStroke
Please post ride files associated with your PS graphs.
TdeCampo
Re: PowerStroke
Post by TdeCampo »
John,
1. Thank you
2. Most likely that file was corrupted. Today I did a ride and powerstroke went OK.
3. I have to work more to increase the power in the left leg and mainly to pull up more on the right side so the curve flattens more.
10/28 is today's and it is ok.
10/27 is the one that I had the problem.
Any suggestions?
-=terry=-
Velocomp_10_27_2021_0952_39_Miles_HiDef.ibr
(1.77 MiB) Downloaded 344 times
Velocomp_10_28_2021_0917_40_Miles_HiDef.ibr
(1.53 MiB) Downloaded 343 times
Re: PowerStroke
I don't know why, but your 10/27 PS data is wrong.
Glad it's working again properly on your 10/28 ride!
TdeCampo
Re: PowerStroke
Post by TdeCampo »
John,
Thank you very much.
I'll be back with a new thread but the correlation between AeroPod vs Garmin V3 is excellent, basically a "carbon copy" even mixing good road with gravel in the same ride. Most of the time I only have AP on the bike and use it as Power Meter. Finally whoever wrote Isaac did a fantastic job, anybody who has ever written a piece of software know the work involved into it. I use Isaac and GoldenCheetah and I have far more of what I need or wish.
Again big thanks.
-=terry=-
Re: PowerStroke
TdeCampo wrote: Fri Oct 29, 2021 5:59 pm John,
Again big thanks.
-=terry=-
Great, and thank you!!!
