2nd profile issue
albafar
2nd profile issue
Post by albafar »
Planet X.ibp
(377 Bytes) Downloaded 241 times
De Rosa.ibp
(413 Bytes) Downloaded 276 times
I have done a calibration ride for two different bikes. And I now have them in Isaac - see attachments.
But in PP only one of them appears - as profile number 2 (I view this when I click Set active profile in Device). Profile number one is labelled Unsaved (type: User Edited). If I then try to send the real 2nd profile via Send profile to device then this 2nd profile replaces the original profile as profile number 2. And so I can continue replacing profile number 2 while profile number 1 stays as Unsaved (type: User Edited). What am I doing wrong - or has done wrong?
Re: 2nd profile issue
I'm not sure where you are getting your profiles from.
You need to connect PP to Isaac, use Edit Profiles to select the profile you want to store, but before sending it to your device, make sure you use the "Set Active Profile" button in the edit profiles window to assign the place where you want the profile stored. You have two profiles, so you should be using two different profiles.
albafar
Post by albafar »
Thanks John it worked 👍
