I got the power pod lite and set up on my previous bike and all was good... Fast forward to today, after a crash 2 months ago, I tried to set it up on a new bike, this morning I took it for the 1st ride and did the calibration process, seemed good, I'm attaching the files generated.
The problem is that I used Isaac software and pushed the setup tab again, and now I think I need to do a second calibration... Is there a way to load the previous profile, and could you help me to check if this calibration was properly done?
thanks in advance
Alejandro
I think I screwed up my setup
- Velocomp_08_04_2021_0714_1_km.ibr
- (14.06 KiB) Downloaded 231 times
- Velocomp_08_04_2021_0717_37_km.ibr
- (464.36 KiB) Downloaded 247 times
Re: I think I screwed up my setup
I used your 37km ride file to adjust profile.
Load the attached profile into your device and all will be well.
Corrected profile and ride file attached.
- Alejandro_Corr.ibp
- (417 Bytes) Downloaded 246 times
- Alejandro_Corr_08_04_2021_0717_37_km.ibr
- (464.22 KiB) Downloaded 229 times
Thanks John!!
will upload and tomorrow will report
John I uploaded the profile you kindly sent to me and today I went our for a ride... do you think is all good now?
Thanks againg
Alejandro
Thanks againg
Alejandro
- Velocomp_08_05_2021_0655_35_km.ibr
- (587.22 KiB) Downloaded 247 times
Assuming there was a strong tailwind on your downhill descent, all is well.
