Calibration look-see!
1k2go
Post by 1k2go »
I was hoping you might have a look at my post calibration ride.
I'm setting up a gravel bike so there are a lot of mixed surfaces on this file. It's a good representation of my outdoor rides will look like. It was quite windy today as well.
Bike:
Specialized Diverge with the PowerPod mounted out front. (I used profile 2)
Tires are 40mm/40psi
I'm using Garmin speed/cadence sensor with the speed sensor on the front hub. (New Batteries in both) I could not get the cadence sensor to recognize through the PowerPod, so I connected directly through the head unit. I'm unsure if that effects the calibration.
I also noticed I had Dynamic selected after my cal. ride. I'll change it to 5 second after your recommendations.
It's pretty tough to find any length of road flat here in NH. :)
Thank in advance,
Marc
Velocomp_07_20_2018_0015_16_Miles.ibr
(34.87 KiB) Downloaded 187 times
GravelBike.Profile.ibp
(368 Bytes) Downloaded 181 times
Re: Calibration look-see!
Everything looks fine. Enjoy!
1k2go
Post by 1k2go »
Thank you!
