Hello,
I calibrated my PP for the first time yesterday (it used to belong to my husband), and I would appreciate it if you could take a look at my calibration file and let me know if you see any indications that I should do it over.
My calibration numbers seemed to be pretty close to the "generic" calibration numbers, but it was a bit windy the day I did my calibration ride and I think I may need to do it over.
Thank you for any guidance or advice.
-Allison
new PP calibration question
- Velocomp_06_24_2021_1145_1_Miles_CalRide.ibr
- (20.9 KiB) Downloaded 200 times
Re: new PP calibration question
Please attach a ride file recorded after the completion of your cal ride.
Thank you.
I am attaching my ride file from after I did the calibration.
Allison
Allison
Your wind calibration was off, likely due to the windy conditions of your cal ride.
I corrected your ride file and profile, attached.
Is your total bike/rider weight of 136 pounds correct?
- Tigre_Corr.ibr
- (312.79 KiB) Downloaded 154 times
- Tigre.ibp
- (559 Bytes) Downloaded 161 times
Thank you very much.
Yes, my bike and I weigh 136lbs.
I have one more question for you: I mostly draft my husband when I ride, should I do a separate drafting calibration, or will the power pod compensate for the drafting?
Thank you again for all of your help and support on this.
Allison
Allison
PowerPod automatically compensates for drafting.
Question: in your cal ride, or in the ride file you posted in this thread, were you doing any drafting?
No, I did the calibration ride solo.
Hello again,
I tried to update your corrected calibration profile in Isaac but got the following error:
"The following parameters are out of range: Fric=.007 (Allowed range: 0.10 to 1000.00)"
Do you have any suggestions?
Thank you,
Allison
Thank you,
Allison
Try loading this profile. I think this one should work.
- Tigre Corr 2.ibp
- (414 Bytes) Downloaded 169 times
