AeroPod CdA not reporting to Garmin
droffsite
Post by droffsite »
Not having much luck (well, any) getting AeroPod CdA to report to Garmin. I have my active profile set to #4.
Recent ride and fit files attached.
Rich
6730043538_ACTIVITY.fit.zip
(170.25 KiB) Downloaded 382 times
Velocomp_05_05_2021_1613_29_Miles_HiDef.ibr
(954.41 KiB) Downloaded 429 times
Re: AeroPod CdA not reporting to Garmin
Follow the instructions to uninstall and then reinstall the AeroPod CdA app and pair AeroPod to your Garmin.
ALSO: there is no DFPM data in the ride file you attached. Re-pair your DFPM to AeroPod, and make sure it is working.
AeroPod CdA_app_081920.pdf
(3.12 MiB) Downloaded 429 times
droffsite
Post by droffsite »
The new app seems to have sorted the problem, thank you.
I don't have a DFPM, just the PowerPod. Is something misconfigured?
Your profile shows a DFPM sensor ID. As long as you are getting good data, you don't need to worry.
droffsite
Post by droffsite »
Velocomp wrote: Thu Jun 03, 2021 3:02 pm Your profile shows a DFPM sensor ID.
Weird, yeah, I just noticed that this afternoon. No idea how that got there.
I also have a heart rate monitor in there (which I do have) that apparently hasn't been connecting for that last several rides.
Is there a way to edit the sensor ID's or enable them via Isaac? Or is that a recalibrate kind of thing only?
Scan/Recalibration is the only sure-proof method.
droffsite
Post by droffsite »
droffsite wrote: Thu Jun 03, 2021 12:32 pm The new app seems to have sorted the problem, thank you.
Sadly, I spoke too soon. Worked once, then not the next time I went out.
Archive.zip
(1.61 MiB) Downloaded 413 times
droffsite wrote: Wed Jun 16, 2021 5:25 pm
Sorry, but your post has absolutely no clues. I don't know what you are reporting as an issue; I don't know why you have attached these ride files; I don't know what to inspect.
droffsite
Post by droffsite »
Velocomp wrote: Wed Jun 16, 2021 8:35 pm [Sorry, but your post has absolutely no clues. I don't know what you are reporting as an issue; I don't know why you have attached these ride files; I don't know what to inspect.
Apologies, same issue as the first post in this thread: there are no wind or slope values showing up in the Garmin files.
droffsite wrote: Thu Jun 17, 2021 12:31 am
Your latest ride file shows that your profile is unchanged. This means that your AP still shows a DFPM wireless ID. You do not have any DFPM data in your ride file and apparently you don't own a DFPM.
The DFPM ID will cause your HR to flatline during the ride at 200 (making your default CdA 200 + 180 / 1000 = 0.380, the value you use.
I don't know if the false DFPM number is causing issues with your ConnectIQ app readings.
I strongly recommend you do a new scan/cal ride, to get rid of the DFPM data. Then, see if things work better.
droffsite
Post by droffsite »
Velocomp wrote: Thu Jun 17, 2021 7:05 am I strongly recommend you do a new scan/cal ride, to get rid of the DFPM data. Then, see if things work better.
Got it. I'll give that a shot.
