Crr Value not Taking
mo_mo
Post by mo_mo »
I've recently had some problems where the PowerPod shows extremely low power or zero. I've tracked it down to the profile somehow becoming corrupted with a Crr that is negative, but when I push a 'good' profile from Isaac back to the PowerPod it won't take the full profile only parts of it.
Starting from Isaac-> Device -> Reset Profile/Device and Reseting all profiles both individually and Complete Device Resets multiple times, I've pulled the default profile from Isaac (attached Profile - Reset Default.pbp). I then send the profile I want Isaac -> Edit -> Edit Profiles -> Send to Device (attached Profile - Dialed-in.ibp). Then I select Extract from Device (Profile - Dialed-in export from bike.ibp). The extracted profile shows correctly except for the Crr & Friction values are wrong. If I correct it by holding Tilt constant, and send it back to the device, it doesn't take.
What's preventing the PowerPod from taking the profile, and how do I work around it?
(458 Bytes) Downloaded 213 times
(368 Bytes) Downloaded 205 times
Profile - Reset Default.ibp
(458 Bytes) Downloaded 210 times
Re: Crr Value not Taking
When the stored value of rolling resistance is negative, this means the orientation of the unit on your bike has shifted significantly.
You should do a new cal ride with your unit in its current position.
mo_mo
Post by mo_mo »
I definitely knocked it out of position and thought I had returned it back to the original stop. I'm not sure why the PowerPod didn't fully take the profile with the bike sitting in a stand, but things appear all good again.
