Calibration Analysis (John)
dmwelk
Post by dmwelk »
John:
Could you look over my two most recent ride files from this weekend and let me know how it looks, as far as calibration. The 4/17 ride file was a 59 mile out and back gravel ride with about 14 miles of asphault thrown in. Any recommendation on a CRR for gravel riding. This was more of a medium pack gravel. The power put out on my end was more than the ride file shows based on perceived exertion, but I knew that before the ride started because I have not created a ride file for gravel. The 4/18 ride file was 54 mile loop of road riding with 2800 feet of elevation gain that started and ended in the same location. Also when looking at the ride file what should I be looking at to gauge calibration? Am I looking at the wind speed relative to bike speed? If so how much variance between the two speeds is considered acceptable? I would appreciate any information you could provide.
Velocomp_04_17_2021_0803_59_Miles.ibr
59 Mile Gravel Out and Back
(1.11 MiB) Downloaded 372 times
Velocomp_04_18_2021_0929_54_Miles.ibr
54 Mile Road Loop
(1.09 MiB) Downloaded 431 times
dmwelk
Re: Ride file Analysis (John)
Post by dmwelk »
TTT
Re: Calibration Analysis (John)
1) When looking at a ride file, I look to see if wind speed and bike speed are comparable. Unless riding in strong head/tail winds (which is obvious to see) then the graphs should be similar. Yours are, so the unit is properly calibrated.
Screen Shot 2021-04-21 at 1.45.11 PM.png (992.64 KiB) Viewed 5392 times
2) For your gravel bike, riding in hard-packed gravel, I adjusted Crr up to 0.014, a value reported by a velocomp forum customer.
Corrected ride file and profile attached. Note that this profile uses the same sensor IDs as your road bike, so you will have to switch profiles manually.
Gravel_Corr_04_17_2021_0803_59_Miles.ibr
(1.11 MiB) Downloaded 434 times
Gravel.ibp
(373 Bytes) Downloaded 401 times
dmwelk
Post by dmwelk »
Velocomp wrote: Wed Apr 21, 2021 1:51 pm 1) When looking at a ride file, I look to see if wind speed and bike speed are comparable. Unless riding in strong head/tail winds (which is obvious to see) then the graphs should be similar. Yours are, so the unit is properly calibrated.
John, thank you. Really appreciate the help.
dmwelk
Post by dmwelk »
John:
I'm using the same bike for both road and gravel, I will just switch profiles when I do one surface over the other. I noticed that my friction number decreased when my CRR was raised from a .0087 for the road profile to .0140 for the gravel profile. My friction went from a mid 7.0 to around a 3.1. Should the friction have dropped? Seems as though it should have went up or at least remained the same.
Oops...my bad.
I uploaded the wrong corrected gravel ride file and profile.
Ride with 0.014 Crr is attached.
Gravel014.ibp
(372 Bytes) Downloaded 385 times
Gravel014_04_17_2021_0803_59_Miles.ibr
(823.53 KiB) Downloaded 413 times
dmwelk
Post by dmwelk »
Velocomp wrote: Thu Apr 22, 2021 4:55 pm Oops...my bad.
Great, Thanks.
