Calibration launch from powerpod
Gilb_Ca
Post by Gilb_Ca »
Is it possible to launch the calibration procedure directly from the Powerpod? Or is it only from Isaac through device/configure?
Re: Calibration launch from powerpod
Gilb_Ca wrote: Wed Apr 07, 2021 9:45 pm Is it possible to launch the calibration procedure directly from the Powerpod? Or is it only from Isaac through device/configure?
On the bike, press-hold the button for about 4 seconds, until it starts flashing. This will initiate a new sensor pairing (make sure you're not close to other bikes with ANT+ sensors). After the pairing process is complete (solid green light, then out), the PowerPod is put into calibration mode. Start riding; the light will soon flash red/green. Click the button to start calibration; the light will flash yellow. Ride to the 50W mark, when the light turns solid red. When safe STOP, turn around, and ride back. The light will flash yellow and watts will climb to 100. When watts reach 100 and the flashing yellow light goes out, you're done.
