iBike Ride Files Say Zero Miles
DrivenUnder
Post by DrivenUnder »
I have a number of rides that, despite being many miles, say 0_miles in the filename. Any idea why that is?
iBike_07_24_2019_1747_0_Miles.ibr
(404.28 KiB) Downloaded 184 times
Re: iBike Ride Files Say Zero Miles
Most likely you are press-holding the button for 12 seconds, causing a hard reset.
When you connect your unit to Isaac the correct time/date will be stored. Make sure to click your button only to awaken your unit.
DrivenUnder
I'm 100% positive I never accidentally hard reset it, and that should not affect the distance in the filename, should it?
Now, I know the battery often goes completely flat if it's unused for a few days, could that be resetting the unit?
