New PowerPod V3. Did cal ride and then today went on 40 mile ride but something seems off about the wind data.
I know that I had some headwind although not much but the ride file shows a tailwind for nearly the entire ride. How can this be corrected? Another cal ride can it be adjusted in the file itself?
I have included the redefine below.
Cal ride also had a very strange profile - or is this what it's supposed to look like?
Wind profile seems to be off
Re: Wind profile seems to be off
Open your ride file and use the "Analyze/Check Calibration" feature to correct the wind factor.
Once you have done this you can transfer the corrected profile to your unit.
Cal ride files always look strange; don't try to analyze them
- narcose.ibp
- (505 Bytes) Downloaded 249 times
- narcose_corr_12_26_2020_0905_40_Miles.ibr
- (617.75 KiB) Downloaded 266 times
