USE of external 5v power pack
crwheelr
Post by crwheelr »
I'm thinking to connect a 5v lithium battery pack to Aeropod to extend its run time. Connect via the microUSB.
Do you see any issue with that?
thanks
Chuck
Re: USE of external 5v power pack
Give it a try...it might be that, when the USB port is being used, that sensor pairing may not work.
A fully charged battery should be good for 20 hours of riding...
crwheelr
Post by crwheelr »
I mainly have the external battery for Garman edge 520, but figured why not connect the Aeropod as well. I'll report back on the functionallity.
Chuck
crwheelr
Post by crwheelr »
an update,
all aeropod functionality is maintained by having an external 5V battery pack plugged in. I have had about 30 riding hours with this configuration without issue. just fyi, below are the links to the two additions to my ride. I use 2 mini bungee style hooked straps to hold the battery to the upper frame right behind the steerer tube.
https://www.amazon.com/gp/product/B01CU ... UTF8&psc=1
https://www.amazon.com/gp/product/B0171 ... UTF8&psc=1
Chuck
