initial altitude
kurt
initial altitude
Post by kurt »
Hello,
Mostly I start from home. However every time the pressure is slightly different and the powerpod thinks my starting altitude is different. (it even once thought I started at -100m altitude).
I know in the ISAAC software there is a functionality to correct it. But to my opinion it is stupid that I have to do it every time (I know I am lazy).
Is it possible that I can fixe the starting altitude to a fix value?
Many thanks
Kurt
Re: initial altitude
The short answer is: no.
PP does not actually measure altitude; like every other device of its type, it measures barometric pressure. This means that, on a given day, the altitude PP displays not only is dependent on altitude, but also weather. Think high and low pressure fronts...
PP converts baro pressure to altitude with a formula that is based on constant weather conditions. So, when weather changes the starting elevation will change, too.
kurt
Post by kurt »
Hello, I understand that the powerpod can't do it. But the ISAAC software should be able to do it automatically because you can do it now manually.
Or am I mistaking?
Kurt
When Isaac opens a ride file, it has no idea where the ride takes place. Therefore it is impossible for Isaac to know the starting elevation
kurt
Post by kurt »
Hello,
Sorry to continue ( I am a little bit stubborn)
I also know that the ISAAC soft were doesn't know where I started (but I do because I always start from home).
I had something in mind like this:
Do you want that ISAAC software update starting elevation automatically each time? if checkbox yes
Which altitude do you want to start? enter a positive number.
However if I am the only one that this want it is indeed not worth wile to do the extra programming.
Kurt
kurt wrote: Sat Oct 24, 2020 2:33 am Hello,
Kurt
This is the first time in 15 years that someone has requested this feature.
