Powerpod V3 Lite - Issues
jamball
Post by jamball »
I have a V3 since April 2020. Mostly it's been ok, but every now and then I have a ride where the power goes to zero or records very low watts. This is after the powerpod has been charged fully before the ride.
Attaching rides from Saturday last so I can figure out what the issue is.
I'm about to sell it and move to DFPM instead.
Velocomp_10_17_2020_1437_27_Miles_HiDef.ibr
(102 KiB) Downloaded 1939 times
Velocomp_10_17_2020_1659_7_Miles_HiDef.ibr
(104.05 KiB) Downloaded 1875 times
Velocomp_10_17_2020_1725_11_Miles_HiDef.ibr
(105.32 KiB) Downloaded 1951 times
Re: Powerpod V3 Lite - Issues
Your calibration is incorrect, causing low watts.
I have corrected your profile and your ride files.
Load the corrected profile into you PPL and maybe you won't want to think about selling it!
Jamball_Corr_10_17_2020_1725_11_Miles_HiDef.ibr
(106.67 KiB) Downloaded 1957 times
Jamball_Corr_10_17_2020_1659_7_Miles_HiDef.ibr
(105.85 KiB) Downloaded 1969 times
Jamball_Corr_10_17_2020_1437_27_Miles_HiDef.ibr
(104.24 KiB) Downloaded 1968 times
Jamball_Corr.ibp
(355 Bytes) Downloaded 1983 times
jamball
Post by jamball »
Thanks a million for that!
So what was wrong with the calibration so I know what to look out for?
If you look at your original files, you'll see that your wind speed was constantly below your bike speed. This is an indicator of incorrect calibration of the wind sensor.
Once you load the corrected file you should not see this problem in your future rides.
jamball
Post by jamball »
I'll hang tight :)
But what would have caused the wind sensor calibration to go off and how would I notice it being wrong?
Since I don't know the particulars of your cal ride, I can't speculate on what went "wrong".
I've already stated how you can identify a problem: wind speed is constantly below bike speed. This is seen in all your ride files.
jamball
Post by jamball »
Great, thanks!!!
