back to back CAL rides
I took 2 cal rides today - back to back. But I cannot figure out how to get each one analyzed - when I read in the files Isaac picks just the last one.
I wanted to do this to see how they would compare if taken in this manner - the same location and the same trail conditions.
I have also bee noticing that the CADENCE is not showing - GARMIN 840 picks it up as I have usually also seen from ISAAC.
Both cal rides are attached. The files are significantly different in size - so I am wondering about that too.
iBike_10_11_2020_1424_1_Miles_CalRide.ibr
(40.09 KiB) Downloaded 229 times
iBike_10_11_2020_1417_1_Miles_CalRide.ibr
(17.84 KiB) Downloaded 239 times
Re: back to back CAL rides
Cal ride files are an artifact of stuff we did 15 years ago.
In current iterations of our products, .calRide files have almost no meaning as ride files.
The calibration factors measured in a cal ride ARE meaningful...but those factors can't be seen until after the ride occurring following the cal ride.
If you want to do this test, do a cal ride, THEN a short "regular" ride, then another cal ride, THEN another short regular ride.
The regular rides are the ones that reveal the settings.
