Good Afternoon John,
I lost my PP V2 and bought myself a PP V3. I am using it with a Garmin Edge 1030 Plus bike-computer, Garmin Speedsensor 2.0 and Garmin Cadence-sensor. And AeroPod Connect IQ app installed.
In Isaac I sometimes use the "Merge GPS" function. With the PP V2 (and Garmin Edge 800) it always worked. I have now tried it with a file from my road-bike and today from my MTB. Both times it just gives the data from the "iBike" (white) in the (pop-up)screen. I don't get the option to select data (normally red) from the Garmin.
Could you give it a look ?
With kind Regards
Paul
Merge GPS in Isaac: PowerPod V3 and Garmin Edge 1030 Plus
- 2020-09-23-09-34-48.zip
- (557.55 KiB) Downloaded 215 times
- PB_2020_09_23_0938_102_km_HiDef.ibr
- (2.76 MiB) Downloaded 217 times
Re: Merge GPS in Isaac: PowerPod V3 and Garmin Edge 1030 Plus
Your activity file was in .fit form.
To merge in Isaac, you need to export it as a .tcx or .gpx file, then do the File Merge
I did this with your file and it worked!
- PB_Corr_2020_09_23_0938_102_km_HiDef.ibr
- (3.04 MiB) Downloaded 228 times
