Power Reading Pedaling Through Sand
SoaringBear
Post by SoaringBear »
As I was struggling to pedal through a section of sand on an otherwise smooth trail my speed slowed and my effort level went way up. The section of sand was about 200-300 feet. However, my PP didn't show power going up but registering lower at about 120w. Is riding through sand a situation that PP does not cope well with?
Thank you
Re: Power Reading Pedaling Through Sand
The reason it's harder to ride through sand is because it is a soft material that deforms when bike tires roll through it. This "softness" translates into a much higher rolling resistance.
PowerPod assumes that rolling resistance conditions do not change. That's a fancy way of saying that it doesn't know when you are riding in sand.
If you post a .ibr ride file, please indicate the place where there is sand. I will show you how do deal with this.
SoaringBear
Thanks, John. Interesting. Then if I were out riding and there were sections of mud the same thing would happen.
I believe it was at 1:47:33 where my pedaling efficiency went down momentarily
Velocomp_08_23_2020_1623_48_Miles_HiDef.ibr
(1.7 MiB) Downloaded 231 times
I note that you had a perpetual headwind (which is unreasonable), so I used the Check Calibration feature to get your wind readings to a normal value.
You have a 6 minute section, starting around 1:47, where your gear ratio drops. I assume this is where you were riding in sand.
To account for the sand, here is what I did:
1) Using the "File/Split File at Cursor" command, I created 3 ride files: A. Up to 1:47; B. 1:47 to 1:53 (sand section); C. 1:53 to end of ride
2) For ride file B, I set Crr to 0.012 (the approximate value of Crr when riding in sand). I saved as file "BSand"
3) I used the "File/Split File/Append File" command I opened File A, then appended file BSand, then appended file C.
In sandy section your watts increased by about 50W.
Corrected ride files and profile attached.
SoaringBearCorr_Sand_08_23_2020_1623_48_Miles_HiDef.ibr
(1.97 MiB) Downloaded 247 times
SoaringBear.ibp
(540 Bytes) Downloaded 229 times
SoaringBear
Thank you. Will check it out.
