Neat trick with AeroPod CdA app for PowerPod/AeroPod
If you have Garmin Connect app installed on your iOS/Android phone, you can use the app to select between 2 field (PowerPod slope/wind) and 4 field (AeroPod CdA/Time Advantage/Slope/Wind) data display
IMG_1613 2.jpeg (215.66 KiB) Viewed 32001 times
mir
Re: Neat trick with AeroPod CdA app for PowerPod/AeroPod
Post by mir »
Will it not be possible to only use a 2-field layout therefore make it possible to display 2 other fields as well?
Yes, the 4 field display works too! Just check the box that says "Display AeroPod Stats"
mir
Post by mir »
Velocomp wrote: Thu Aug 20, 2020 5:30 pm Yes, the 4 field display works too! Just check the box that says "Display AeroPod Stats"
I ment 2 other fields like cadence and heartbeat etc.
The Garmin computers allow you to create your own panel.
Currently, the suggested layout for the AeroPod app was described as 2 data views.
The top (or Bottom) data was the aeropod 2x2 and the other could be your choice of anything else captured by the computer. The suggested data was POWER.
It is entirely possible (but I do not know if the AeroPod portion scales as you change the 2 data fields to 3), for example - have not tried it.
By doing this you would potentially have space for the AeroPod portion, POWER and another item for display ---- experiment with your own setup.
mir
Post by mir »
I will do that and report back my findings (currently I have problems accessing apps.garmin.com).
mir
Post by mir »
It worked by disabling Aero Pod fields and then choose 4B screen layout in edge 830. See attached image
kdx200
Post by kdx200 »
worked here!! NICEEEEE!!!
thank you OLEKSIY!!!
kdx200
Post by kdx200 »
2 days of testing>
the fields are ok...the reading is difficult... very very tiny numbers. There is a lot of space unused. I have 4 fields... for example speed and power with nice visiblity...and the slope/wind not...perhaps the " font size" is the half as it should be .
is it ok or im doing something wrong?
thanks!!
I am also seeing the font issue.
Other than that, it is great to have the other data fields "gone"
Return to “Installation/Usage Instructions and Videos”
