Calibration without pairing sensors
Patspeedy
Post by Patspeedy »
Is it possible to force the Aeropod into a new calibration mode without having it pair to sensors when holding button pressed until green led flashes , reason I am asking is that when changing cockpit position during testing I would be wearing a heart rate strap and the Aeropod will pick that up if I let it sensor pair , sorry if this has been answered before
Re: Calibration without pairing sensors
To force a calibration in the field you will need to do a sensor pairing.
If AeroPod picks up your HR sensor during a pairing that's OK; the HR field of your ride file will still have CdA data in it (HR data is not recorded).
If you do a pairing in the field make sure you're far away from any other bikes; you don't want to pair to another bike's sensors!
Patspeedy
Post by Patspeedy »
Thank you John , quick answer much appreciated
