PowerPod Windsensor broken ?
PaulK32
Post by PaulK32 »
Good Afternoon John,
4 years an enthousiastic user of the PowerPod (V2 BLE), 1024 rides.
15-05-2020 I made a tour on my roadbike. PowerPod worked fine.
16-05-2020 I made a tour on my MTB. PowerPod gave value 0 driving on the "flat". When I did a hill it gave a value, some 150 tot 300W lower then "normal" on that part of the track. During the ride I thought "windsensor ?" or the CR2032 battery from de speedsensor ? At home I gave the speedsensor a new battery.
17-05-2020 I made a tour on my MTB. Again value 0 on the first hunderd meters. I stopped, changed the angle of the PowerPod a little. It gave high values as aspected (saw 1193W on the Garmin, 12900W in the software at home) and the value went down and after a minute it was 0 again. I stopped, pushed the button and did a new calibration ride. It went to 100 and then there came a value of 70W and the value went down, after 15 seconds it was 0. I completed the ride and saw at ascents that there came "above 0" values (max 430W) on the Garmin.
Can you help me with some options ?
a. Just use a brush to clean the windport ?
b. Is the windsensor blocked (fly ?) and can I try to make it clean ? Should I fill it with water, shake and let it dry ?
I have attached the 3 rides for your information. Perhaps the data gives you a hint. The 2018-07-20 file is the file from today 17-05-2020, the calibration gave the PowerPod a new date.
With kind Regards,
Paul
PB_2020_05_15_1104_79_km_HiDef.ibr
(1.67 MiB) Downloaded 242 times
PB_2020_05_16_1359_40_km_HiDef.ibr
(908.61 KiB) Downloaded 273 times
PB_2018_07_20_0000_55_km_HiDef.ibr
(746.67 KiB) Downloaded 254 times
Re: PowerPod Windsensor broken ?
Your wind port is not the problem.
It looks like you tweaked your profile between your two MTB rides.
On the final ride you did a hard reset of the unit prior to riding, but you also did a new sensor pairing (your HR ID is different).
Somehow the rolling resistance was set to a negative value of -0.03! Effectively, this means your unit thinks your bike is being pushed down the road from behind, pretty strongly!
I set your profile to a more reasonable MTB value of +0.006. Once I do this your watts return to normal values. Corrected file attached.
You should do a new cal ride. Make sure your PP is locked on to the bike and cannot rotate. Also, don't change its rotational position during the ride.
PB_Corr_2018_07_20_0000_55_km_HiDef.ibr
(782.97 KiB) Downloaded 265 times
PaulK32
Post by PaulK32 »
Thank you John. I did use a New HR sensor.
I will do test rides with the bikes next days.
Happy te PowerPoint is not the problem, just me as the user :-)
PaulK32
Post by PaulK32 »
Thank you John. PowerPod is working fine.
I will do beter checks in Isaac next time myself. Have not had this "negative" Crr.
