Check my Cal ride please.
TonySJ
Post by TonySJ »
I'm wondering if you could check the attached Cal ride for me please. Prior Id noticed the power reading were reading high than I would expect.
Rider details; 75kg 1;78cm, bike+rider W 198lb, summer carbon bike on hoods, 700 x 25c Conti 4000 Sii at 90 rear 85 front.
I'm fairly happy its mounted correctly having had the PP for a few years and switched between winter and summer bikes and always input details again for the bike Im swapping over to so its fresh and accurate.
The ride is slight downhill for 100mtrs then a 90degree right at a small roundabout to follow a fairly straight/flat out before the return back ride. Light winds on the day.
Regards.
Tony.
iBike_05_13_2020_1719_1_Miles_HiDef.ibr
(25.01 KiB) Downloaded 234 times
Re: Check my Cal ride please.
For the first 5 minutes of any new ride, PP is internally checking its settings.
Your ride file is only 3 minutes long, so it's tough to draw any conclusions about accelerometer settings.
Elevation data shows a slight UPHILL for the first minute, then a slight drop, then another slow elevation increase until the final minute of the ride.
Wind looks to be OK.
TonySJ
Post by TonySJ »
The 1st minute which you say was up hill should be a downhill minute which is strange!.
I've attached a 40 mile ride I did yesterday, Saturday, the first ride after the Cali ride I initially posted.
The beginning of the ride is mainly downhill for about 4 minutes then a short uphill before a flat couple of minutes.
From 9;20 to 13;20 was a uphill stretch at 4% average for 3/4 of a mile.
If you could have a quick look at that part and see if anything appears ok please.
Thanks again.
Regards.
TonySJ.
iBike_05_16_2020_0838_41_Miles_HiDef.ibr
(1.55 MiB) Downloaded 233 times
TonySJ wrote: Sun May 17, 2020 1:55 pm Hi John,
Thanks again.
Regards.
TonySJ.
This is a very long ride file, over a widely varying course. It looks like you had sections with lots of wind. There are other sections where there is very little ground wind.
It MIGHT be that your wind readings are a bit high, but I can't tell for sure. If possible post another ride file where you have less ground wind, or a ride where you have more of a loop route.
TonySJ
Post by TonySJ »
This is todays, tuesday, ride of 21 miles in a loop.1400ft elevation. From about 24 minutes to 34 minutes the wind was a tail wind so I thought id mention that so it may help possibly.
If you could have a look at this file and give me your thoughts on if it looks OK.
Regards.
Tony.
iBike_05_19_2020_1109_21_Miles_HiDef.ibr
(657.7 KiB) Downloaded 242 times
TonySJ wrote: Tue May 19, 2020 11:53 am Hi John,
Regards.
Tony.
This looks OK. On some descents, while pedaling your watts seem a bit high. This could be because you are going into a tuck.
TonySJ
Post by TonySJ »
Velocomp wrote: Tue May 19, 2020 2:43 pm
Regards.
Tony.
Your probably right John as I was pushing it at times. I think I may need to do an FTP test now Im getting back to my Summer levels. Last time I did a test was last July so it well over due.
Thanks again John.
Regards.
Tony.
