Hello:
Attached path file in mtb to check if everything is correct. Before calibrating I put a cda of 0.450 and a crr 0.0080, I have seen that they are values that are usually put for mtb. It seems to me that it gives high watts in descents if you are pedaling and in other occasions in general I appreciate that it gives high watts, I have doubts; So I want you to review it.
The data is as follows:
MTB bike weight: 12,800 kilograms
Rider weight: 68,500 kilograms
Cyclist height: 178 centimeters
Powerpod installed on handlebar
29'x2.25 tires with a pressure of 1.8 bar
Another question I have. How does powerpod detect if you are going through an area with a lot of loose stone or mud, where you need to apply more force to advance and therefore more watts.
Thanks and best regards
MTB route review. High watts
- iBike_05_10_2020_1122_52_km.ibr
- (487.2 KiB) Downloaded 300 times
Re: MTB route review. High watts
In general your ride file is fine and your PP is correctly setup and calibrated.
There are a few places, when you first start descending, where watts are a bit high. This is because of the MTB configuration with suspension shock. You'll notice that, after about a minute, those watts stabilize.
PP "listens" to the roughness of the road and adjusts rolling resistance accordingly. This works well with "noisy" loose stone, but not as well with mud.
Hello:
I am attaching screenshots of my perfir for the mtb bike to check if everything is correct. I have the doubt if DPS has to be in dynamic or in zero seconds, the power in the Garmin took it to 3 seconds.
Greetings and thank you
- pantalla wireless.jpg (140.33 KiB) Viewed 3952 times
- pantalla basic.jpg (136.22 KiB) Viewed 3952 times
- pantalla advanced.jpg (142.86 KiB) Viewed 3952 times
