hola jhon,estoy viendo que en bajadas los watios se disparan para arriba casi sin esfuerzo...me gustaria que vieras este recorrido y si hay algo mal..
gracias.
calibrar power
calibrar power
- iBike_05_03_2020_0913_55_km.ibr
- (452.63 KiB) Downloaded 223 times
Re: calibrar power
There are a couple of places in your ride where you are descending pretty steep slopes, around -5%, and where you are pedaling, where watts are high for a few seconds. If you went into any kind of tuck during these descents, that would cause high watts.
Overall your ride file looks fine.
Re: calibrar power
Entonces puede decirse que está bien calibrado??
O ese exceso de watios puede cambiar los resultados finales??
Gracias
Gracias
Re: calibrar power
Imagine a photo of someone you admire. The face is perfect, except for a small blemish on one cheek.
Do you smile at the beauty of the face, or does the blemish make it impossible?
Your ride was 55 KM long, over a period of 2 hours and 11 minutes. Your potentially high watts were about 29 seconds long.
What do you choose to see?
Re: calibrar power
Muchas gracias jhon!!!!
Seguiré entrenando con esa calibración!!!
