File>Merge GPS option gone
obidavekenobe
Post by obidavekenobe »
Somehow the option to merge gps data within Isaac software had disappeared from the 'File' menu. I have been able to use File>Merge... to added GPS data from my Wahoo ride file in the past. However, since my last ride that option no longer appears in the File menu, it's gone. How can I get it back?
Thank you.
Re: File>Merge GPS option gone
Hmm...what version of Isaac do you have? Mac or PC?
Nothing has changed in Isaac. You might want to restart your computer.
obidavekenobe
I'm running version 5.1 on PC. Windows 10.
To be more specific,I'm running it on a surface pro 2017 i5, 8gb ram.
I've rebooted several times and no change.
In the Isaac "View" menu, make sure "Menus" is set to the "Advanced" view.
Screen Shot 2020-03-04 at 5.52.35 AM.png (183.21 KiB) Viewed 12953 times
If you're not set to "Advanced" menu display you won't see the Merge option.
Also make sure you're set to "PowerPod/Newton"
Screen Shot 2020-03-04 at 5.49.53 AM.png (277.35 KiB) Viewed 12953 times
obidavekenobe
Ahhh! Advanced mode. Somehow it got set in standard menus.
texmurphy
Post by texmurphy »
Ctrl-M will also do the GPS Merge. I think this works even if not in Advanced Menus.
(Just don't be in the activity name field edit or Isaac will see a newline).
texmurphy wrote: Thu Mar 05, 2020 9:18 am Ctrl-M will also do the GPS Merge. I think this works even if not in Advanced Menus.
In Isaac/Win use "Ctrl-m" (lower case "m")
In Isaac/Mac use "command/m" (lower case "m")
Note that these these shortcuts don't work unless Isaac View is set to Advanced Menus.
