Move from PP BLE to PP V3
texbiker
Post by texbiker »
What is the best way to move 2 bikes from a PP BLE to the PP V3? Can I transfer the profiles using Issac? Should I do that? Start from scratch and create new profiles? Create new profiles with a ride or use the Powerhouse app?
I want the least frustration possible.
spangelsaregreat
Re: Move from PP BLE to PP V3
Post by spangelsaregreat »
You will need to do new calibration rides anyway for each profile so just as well setting up new profiles.
texbiker wrote: Wed Feb 19, 2020 1:14 pm What is the best way to move 2 bikes from a PP BLE to the PP V3? Can I transfer the profiles using Issac? Should I do that? Start from scratch and create new profiles? Create new profiles with a ride or use the Powerhouse app?
You should do new setups for your new PPV3. Here are two ways to set it up
Isaac:
1) Connect PP to Isaac. Set up profile 1 using the "Device/Setup Device" wizard in Isaac
2) Select "Best Accuracy" in the final step of the wizard
3) Pair PP to your bike 1 sensors (make sure other bike sensors are off)
4) Pair PP to your bike computer
5) Attach PP to your bike, then do an out-back cal ride
Repeat the above steps for bike 2, selecting profile 2 in Isaac
PowerHouse Bike app
1) Follow the video, starting at about 3:26, to set up profile 1/bike 1
https://www.youtube.com/watch?v=eR3k1uQ ... e=youtu.be
2) Pair PP to your bike 1 sensors (make sure other bike sensors are off)
3) Pair PP to your bike computer
4) Attach PP to your bike, then do an out-back cal ride
Repeat the above steps for bike 2, selecting bike 2 in the app.
