1. First I was getting speeds that were extraordinary - the iAero had me doing 35 mph on average and 209 max! Wow, these power meters DO make you fast
2. It seemed to me that the Cinqo was reading low - I have an SRM PCV on my other bike and my RPE didn't match my power output. Only when surging up a hill or riding at a recovery pace did my RPE match my power output IMO. At tempo pace it felt like the Cinqo was reading low. This could be due to point # 4 below.
3. There is a serious lag for the power to drop to 0 after I stop pedaling - This is something I experienced w my 1st gen iBike so I thoguth maybe I was getting power readings from the iBike and NOT the Cinqo - To check I covered the air pressure port, pedaled, and low and behold I was putting out power so it was the Cinqo that was reading my wattage. I'v read elswhere that this is a firmware issue w the iAero. Anyone fixed this w their setup?
4. The pairing process was easy and straight forward but I couldn't zero out the PM - I kept trying to do this under WLS CFG > PCAL and i kept getting a message that it was in PROC or it said that the process FAILED. Any thoughts?
Last, I downloaded my file, but I did not bother to do a tilt or coastdown before the ride, because for now I'm only interested in data from the Cinqo. I can see data from both devices in the iBike 2 SW. I want to drag and drop the Cinqo data into CP, but I just can't seem to figure how to do that? If I save the file and then drag and drop it into CP all I get is the iBike data. How do I isolate and save the Cinqo data for import into CP? Anyone crack the code on this one?
Thanks in advance for the help.
gene r
