Use Aeropod without isaac
Can i use aeropod only with Garmin Connect IQ APP??
Re: Use Aeropod without isaac
Isaac helps set up AeroPod for best accuracy results.
You can use AeroPod without Isaac, and your results will be CONSISTENT, but not necessarily as accurate.
I had test this morning aeropod with Garmin IQ Garmin 520
1 : Stages power and speed sensor paired. Ok
2 : After i paired aeropod with Garmin ( ok AeroPod is like a power Meter) And my StagesPower is disconected because Garmin 520 can use only powermeter
3 : I made calibration ride. 50w. Turn and go back to 100 W. Ok
4 : Power screen appair and show the power when i ride
But not CDA wind speed slope Time avantage. Only power
Did i mate à mistake?
You need to pair your stages powermeter with the aeropod. Please see https://velocompforum.com/download/file.php?id=5278
Regards,
Roedie
Regards,
Roedie
What usually works for me is to replace the Aeropod connect IQ data field with something else temporarily, and then change the field back to the Aeropod connectIQ data field. Fortunately when this happens, the Aeropod is still recording your data for analysis on Isaac
Everything is paired
I had installed issac on my iMac ( not easy) configuration AeroPod profil 4
I am going to test ride now..... i hope everything Will be ok
Screen is ok but dans values cda and slope are wrong.
Slope values move quickly -15%to +15% and i ride test on a flat road
Cda value move 0,2 to 0,45 in the same position during serial minutes ride
Wind speed is ok
Why slope value is so unstable?
Wind speed is ok
Hi my files
I you can analyse please?
I had no cadio sensor
stages power
speed sensor
many thanks to help me
stages power
speed sensor
- iBike_08_27_2019_1843_5_Miles_HiDef.ibr
- (230.25 KiB) Downloaded 816 times
- iBike_08_27_2019_1908_7_Miles_HiDef.ibr
- (318.63 KiB) Downloaded 841 times
Please send images showing your front fork, and showing how AP is attached to your bike.
my aeropod fixation
- Image 2.jpeg (189.19 KiB) Viewed 29034 times
Your cables are touching AeroPod. I think this may be causing unstable readings.
Please move your AeroPod, or your cables so that they do not touch AP.
ok I am going to test tomorrow
Slope is measuring with barometric sensor and distance calculated with speed sensor?
do you think that the vibrations of the cables can cause such a big disturbance on the pressure sensor ??
I test tomorrow and I tell tou
thanks to you're quick help
Yes, the location of your cables could be a real problem. It looks like one of your cables passes directly next to the baro port hole.
it doesn't work I changed the position of the aeropod
slope is unstable
Other bug average speed show 21km/h it to low, i think because my speed sensor is bad ( btwin decatlhon sensor) , the speed value is unstable and move large in a range (10km/h)
I think it can have an influence on the slope ...
your opinion?? should i buy an other sensor?? garmin
slope is unstable
- iBike_08_29_2019_1430_3_km_HiDef.ibr
- (37.79 KiB) Downloaded 854 times
I think you've found the culprit; when speed is unstable all the other readings will be wrong.agud wrote: ↑Thu Aug 29, 2019 10:52 am it doesn't work I changed the position of the aeropod
slope is unstable
I would get a Garmin magnet-less sensor. Put it on your front hub and I think you will get much better results.
ok GPS speed is better and very stable, more than my speed sensor
I am going to try a garmin speed sensor ans I tell you
this one is very good?? garmin speed sensor2
https://www.probikeshop.fr/capteur-de-v ... 68137.html
Yesagud wrote: ↑Fri Aug 30, 2019 11:38 am this one is very good?? garmin speed sensor2
HI slope is ok now with garmin speed sensor
but problem of calibration , because the calibration process was done too quickly I think
CDA don't move it stay at 0,305
what is the problem??
- iBike_09_17_2018_0004_0_km_HiDef.ibr
- (192.97 KiB) Downloaded 663 times
You do not have any DFPM data in your ride file, which means that your DFPM sensor is not paired to your AP.
Make sure your DFPM is awake when you do the pairing process.
I agree that the Garmin speed sensor is giving you MUCH better speed and slope data.
I have to redo tests but it's weird because the last time my power sensor was connected without problem
Hi I made a new test, with my road bike , It seems better ???
what do you think about this test ??? thanks
- iBike_09_10_2019_1701_10_km_HiDef.ibr
- (265.71 KiB) Downloaded 799 times
Looks good!
What speed sensor were you using prior to switching to the Garmin? It was not a good speed sensor...
btwin sensor I was bad i think
https://www.decathlon.fr/p/kit-de-capte ... R-p-145727
I going to make an another test with my TTbike and recalibration with very good conditions
thank for you're help
