Battery Charge
Kcblair
Battery Charge
Post by Kcblair »
Hello guys. Is it normal for battery to completely discharge, after setting idle for 10 days ? Battery was fully charged, when I last rode this bike . Thanks. KB
Re: Battery Charge
How old is your unit?
Complete discharge of a full battery in 10 days is not normal unless:
1. the unit is old, or
2. the battery has not been properly maintained (like any rechargeable battery device, PP battery should be periodically charged full every 4 weeks).
Kcblair
Re: Battery Charge
Post by Kcblair »
The unit is new, purchased in Apr 2019. I charge after every ride. Last rode bike that PP is installed on Jul 9, rode today, pushed start button, nothing. Continued with ride, plugged into PC and charging now. Light flashing red. What is rechargeable battery device ?KB
Edit:what is not properly maintaining a rechargeable battery device , sorry , I was a little confused. Once the battery is recharged, it is left on a particular bike, stored in my climatic controlled bike room. KB
FrankH
Re: Battery Charge
Post by FrankH »
John,
I asked the same question over a year ago, https://velocompforum.com/viewtopic.php ... 301#p24301
Your reply indicated that discharging in 10 days is normal, now you seem to be saying it should last at least four weeks
Re: Battery Charge
FrankH wrote: Fri Jul 19, 2019 2:46 pm John,
My response in the prior post did not have a time frame. My response was:
"PP will slowly discharge when not used. It is fine to keep it connected to a USB charger when not in use."
If PP is fully charged it will take about 3 weeks for its battery to fully discharge. NOTE: new PowerPod V3 takes about 3 months...
Re: Battery Charge
Kcblair wrote: Fri Jul 19, 2019 11:04 am The unit is new, purchased in Apr 2019. I charge after every ride. Last rode bike that PP is installed on Jul 9, rode today, pushed start button, nothing. Continued with ride, plugged into PC and charging now. Light flashing red. What is rechargeable battery device ?KB
Please provide the serial number of your unit.
When you charge PP, its red light will flash while charging. When the battery is fully charged the light will go out.
Kcblair
Re: Battery Charge
Post by Kcblair »
Hello John,
Ser nbr is : 02-28-19-08-04-0C-B0-00-03-00-93-03-BE-7F-10-13
Yes, that's what the unit does while charging and is completed. KB
Re: Battery Charge
Kcblair wrote: Fri Jul 19, 2019 6:26 pm Hello John,
You have one of our newer circuit boards. If your unit is fully charged, then when in storage you should get well over 2 months of slow discharge. Note that this assumes the unit is NOT used...it is just sitting in storage.
Kcblair
Re: Battery Charge
Post by Kcblair »
Thanks John,
Should I , after the PP is fully charged, give it 5 clicks, to ensure it is off ? KB.
Re: Battery Charge
Kcblair wrote: Fri Jul 19, 2019 7:00 pm Thanks John,
You can do this if you wish. Note, however, that PP will turn itself off after 20 minutes of inactivity.
Kcblair
Re: Battery Charge
Post by Kcblair »
Thanks John, for your assistance . Ill keep tabs on this and charge the night before using .KB
Psycho Mike
Re: Battery Charge
Post by Psycho Mike »
Here's another question on the topic. - Power bricks / blocks.
Several of them have the ability to charge at different currents (i.e. 1A and 2A) thanks to the different phones on the market. Is there any limitation on what the PP will accommodate? I've got a multi-day cycling trip coming up and I'll need to use a block to recharge my Garmin and PP.
2018 Bowman Palace:R
2009 Knolly Delirium T
conquercancer.ca/goto/Psycho_Mike_2019
Re: Battery Charge
No limitation... :D
Charcoal007
Re: Battery Charge
Post by Charcoal007 »
I have a powerpod v3 purchased in April 2019.
I’ve noticed that when I charge the unit using a power outlet the unit is set to recalibrate.
Is this normal?
I would prefer it not to be in recalibrate mode. Can this be changed?
When I charge through PC USB port this doesn’t happen.
Re: Battery Charge
Hmm...this should not happen. Make sure that when you plug your PP in that you aren't press-holding the button for 12 seconds. This would force a new cal ride.
Charcoal007
Re: Battery Charge
I'm sure that I didn't press the power button when charging.
I might have messed up the pairing with my head unit and accidently forced a calc ride to start.
Cheers
awoodburn
Re: Battery Charge
Post by awoodburn »
Does the rechargeable battery eventually deteriorate so it won’t hold charge - my charger flashes red for about 20mins and then goes off but the unit won’t function for more than 2hrs before going flat . This is similar to some of my garmin after while where they won’t take a full charge
Re: Battery Charge
Zoltan
Re: Battery Charge
Post by Zoltan »
Velocomp wrote: Fri Jul 19, 2019 5:19 pm
Unfortunately I dont know the type of rechargable battery inside PP (or previous products like Newton), thus I have just an idea to be confirmed or rejected.
I have read that it is a good solution to keep some types of rechargable batteries in really cold places even in a refrigerator, PROVIDED they are properly sealed in order to avoid moisture.
Sidenote: since in case of PP and it is true for any Velocomp products we speak about not rechargable batteries, but devices with these batteries inside, and these devices are designed for outdoors usage even with potetial rain, moisture cannot cause a corrosion of the batteries inside.
So my idea, or rather question is that is it OK to put and keep PP (or Newton in my case) to the refrigerator between two rides in order to decrease the daily extent of discharge? As an alternative solution to keeping it connected to a USB charger?
Re: Battery Charge
Zoltan wrote: Wed Dec 08, 2021 4:35 am
I have read nothing in the literature that says that rechargeable batteries will discharge more slowly if they are cold.
That said, I would be uncomfortable putting our PMs in a refrigerator between rides:
1) After removing the device from the refrigerator and putting on the bike outdoors, there is the possibility of condensation inside the device, on the circuit board. Not good...
2) For the best stability of power measurements, it's best if the unit is operated at outdoor temperatures
Re: Battery Charge
A simple web search on rechargeable lithium battery storage or handling - I found plenty of information and nothing suggested storing them in the refrigerator.
One comment found:
Most battery manufacturers do not recommend storing batteries in the fridge. While the cooler temperature might lengthen the battery life, the moisture from inside the refrigerator could damage the battery in other ways. ... This precaution will help keep the high humidity inside a fridge away from the batteries.(and other internal electronics as John mentioned.)
To add to this:
Store the PP in a cool dry place - best around 59 Degrees F or room temp is adequate. But not hot, which will degrade the battery.
It appears that the PP is designed with an internal limit to charging (limited trickle charge) so that you can leave them connected to a USB charger, but that is a waste of resources.
The internal PP battery holds a charge for quite some time - granted the Newton probably is an older generation technology.
Zoltan
Re: Battery Charge
Post by Zoltan »
lorduintah wrote: Thu Dec 09, 2021 12:48 pm A simple web search on rechargeable lithium battery storage or handling - I found plenty of information and nothing suggested storing them in the refrigerator.
One comment found:
To add to this:
https://m.greenway-battery.com/news/Sto ... -1424.html
“ Storing rechargeable batteries in the refrigerator is an alternative to trickle-charging. By keeping NiMH batteries at temperatures below freezing, the self-discharge rate can be reduced to about 1-3 percent each month. ”
Since Newton discharges fully in 10-21 days when it is switched off, if there is a NiMH battery inside then theoratically there is a chance to win a lot with cooling
Note: I started my original question with making it clear that I have no knowledge about the type of batteries within Newton or PP.
But since lithium is much much better than NiMH or NiCd as regards self-discharging rate I would not be surprised if Newton has not lithium inside, but some nickel-based battery.
Re: Battery Charge
The likely source of drain in your Newton is related to the much older design of its circuit.
We made circuit design changes in PP V4 that substantially reduces battery drain when the unit is off.
Zoltan
Re: Battery Charge
Post by Zoltan »
Out of pure curiosity, and on my own responsability I put my beloved Newton into our freezer set to -16 C degrees (3.2 F). I applied triple seals in order to create a robust shield.
The daily discharge rate dropped down to 3-3.3%points. I can’t specify more exact number, because I am not sure about the exact time of its putting in.
I don’t say at all anybody should follow me. It was just a piece of fun for me.
