Can you check my calibration?
Denodan
Post by Denodan »
I managed to entered my correct bike weight by my scales, weighted myself; then weighed myself with bike and took off my weight and got hr strap going and works with powerpod and redid a calibration, so could you check it and see if it's ok? Near the ballpark will be fine by me?
iBike_07_20_2018_0010_5_Miles.ibr
(68.21 KiB) Downloaded 321 times
Re: Can you check my calibration?
What is your bike weight and rider weight?
Denodan
Post by Denodan »
63.5kg my weight, bike 15.5kg
Denodan wrote: Sun Jun 16, 2019 3:18 pm 63.5kg my weight, bike 15.5kg
I have adjusted your profile to have to have correct bike and rider weight.
Load this corrected profile into your device:
1) Place the profile on your desktop
2) Attach device to Isaac
3) Use the Isaac command "Edit/Edit Profiles/Import" to import the attached profile into Isaac.
4) Use the Isaac command "Edit/Edit Profiles/Send to Device" to put the profile into your device
Denodan.ibp
(412 Bytes) Downloaded 332 times
Denodan
Post by Denodan »
entered my updated profile. Here my ride, but calorie count seems lower. Will i need to recalibrate? to get calories right or is it linked with power output?
iBike_06_17_2019_0956_8_km.ibr
(58.17 KiB) Downloaded 301 times
Velocomp wrote: Sun Jun 16, 2019 7:03 pm
Your wind sensor appears to be obstructed. This would cause low power.
Calories are linked to power output. Calories are power added up over time.
Your weight was too high in your original profile. It is not surprising that your power/calories dropped, but please check your wind sensor for blockage.
Denodan
Post by Denodan »
I have the cables well away from the wind sensor. Seems strange as I had tied my cables back.
Thought I did put my proper weight in profile. 63.5kg? As for cables, have them away from powerpod air duct
Looks OK. Do another ride and post it.
Denodan
Post by Denodan »
Here is another ride. I did tie another cable just in case, so hope this is better?
iBike_06_17_2019_1136_3_km.ibr
(31.08 KiB) Downloaded 339 times
This looks better
Denodan
Post by Denodan »
Thanks for looking for me and your help. Hope you have a wonderful day.
I have ordered a front mount so I can move it out the front of the handle bars away from cables.
