Powerpod dropping to 0W after descents
jstrauss79
My PowerPod ANT/BTE seems to be accurate, and works well until I put in a 5-10 minute descent. It reads 0 watts as I descend, which is fine cause I am not tripping the cadence sensor (using ANT+ cadence and speed). The only issue is that it locks up on 0W afterward. I can turn off the unit and turn it back on, and I don't need to calibrate it, but it also then starts a new file. Any suggestions?
Re: Powerpod dropping to 0W after descents
Hmm...please post a .ibr ride file showing this problem.
jstrauss79
Attached is part of a ride from yesterday where this happened again. I had to wait for a friend to join, so the unit fell asleep and I woke it up with one press of the button and began recording this file.
On the descent, it tends to stick to 0W unless you really go at it, which I get, since gravity is doing most of the work. But then at the end, it just goes to 0 and the file gets cut.
Following this, I turn off the unit (5 presses, LED does stoplight colors) and then turn it on with one press. The first time it went up to about 200W for a few seconds and dropped back to 0W. The next several times I went through this process, it just reports 0W constantly.
I am pairing to a Elemnt Bolt, with a magnetic speed and cadence from Amazon.
https://www.amazon.com/CooSpo-Cadence-C ... B07BSTJWD2
Note: tried the garmin magnetless speed and cadence and didn't have much luck. I have two of these style sensors seem to be consistent with pairing.
- iBike_05_29_2019_1242_13_Miles_HiDef.ibr
- Sunshine Canyon from Mapleton/30th.
- (646.86 KiB) Downloaded 188 times
jstrauss79
Forgot to mention, after this happens it doesn't seem to write anything to to memory. So there isn't a file with 0W throughout.
In the ride file you posted, speed abruptly dropped to zero at the end. It looks like your speed sensor stopped functioning. This would cause the ride file to stop recording.
Do the following:
1) Make sure the speed sensor is mounted on the front wheel hub
2) Replace speed sensor battery
3) When installing the new battery, momentarily put it in backwards. This does a hard reset of the sensor. Then, install the battery normally
Hopefully this will fix things.
Do the following:
jstrauss79
Thanks John,
I will try that out.
