something seems out of whack; calibration check pls
flahutewannabe
Post by flahutewannabe »
Back riding after a long winter of rehab/prehab to postpone knee surgery. First ride in a while; not confident calibration is correct as watts and PE/HR (which I know is a lagging indicator) don't seem to jive well. Pretty windy; very low watts going up grades into the wind at slower speeds with higher HR/PE, much higher watts reported while on low downhill grades with the tailwind with HR and PE both lower
iBike_04_03_2019_1540_18_Miles.ibr
(189.38 KiB) Downloaded 244 times
. What tweaks might be made to bring things more in line.
Re: something seems out of whack; calibration check pls
Your PP is in trainer mode. You need to switch back to outdoor mode...
