What happened?
naavt
What happened?
Post by naavt »
Never had an issue with my PP, even didn't upgraded FW since it always worked flawlessly until yesterday.
For the first time ever, my PP stop working and I just don't know why. It was at the middle of a ride. I've stopped for coffee with my Bolt computer marking some 100 and so watts, didn't disconnect PP or Bolt (which pauses automatically when I stop).
Coming back to ride I've noticed that the power number on the Bolt was stuck. At motion, I've just pressed PP 5 times to power it off and power it on some seconds after to no avail. Same power number on Bolt computer.
I'm sending both files for you to check. I'll appreciate your insight on this matter please. Best regards.
iBike_03_02_2019_0915_79_km.ibr
(730.73 KiB) Downloaded 262 times
2019-03-02-091643-ELEMNT E2E4-143-0.fit.gz
(263.07 KiB) Downloaded 279 times
Re: What happened?
Hmm...let's assume it was PowerPod, not Wahoo, that was "stuck".
You can do a hard reset of PP (press-hold for 12 seconds, until light goes out then comes back on). That will unstick the PP.
naavt
Re: What happened?
Post by naavt »
Everything back to normal. Thanks!
