please check file
bunkasthedog
please check file
Post by bunkasthedog »
I wonder if you can check the attached file. I don't think it is reading right. I find that when i'm riding uphill the power reading is higher with less effort than even on slight downhills where i'm putting in a lot more effort. also Power reads zero when i'm clearly peddling faster than gravity alone would suggest. The date on the file name is wrong as i rode this today. not sure how to change that.
iBike_07_20_2018_0039_30_Miles.ibr
(417.03 KiB) Downloaded 311 times
thanks for the help.
Re: please check file
This is set up for a TT bike; is that correct?
Please point to specific places in the ride file where you think there might be a problem.
FrankH
Post by FrankH »
bunkasthedog wrote: Sat Feb 16, 2019 11:14 am <snip>
In Windows: right click then choose rename
or
Two left clicks (i.e click, pause, click, not a double click which would open the file) then edit the file name.
To set PowerPod's date make sure your system time is right then use Isaac
Device - Setup - Set Time and Date.
In edit - Preferences you can choose the autoname format. I have mine set to YYYY_MM_DD, it makes it easier to sort.
EDITED to add:
Use Isaac to fix the time and date in the ride file:
Tools - Repair - Fix Date & Time in Ride File
