Emparejamiento
Matteo
Emparejamiento
Post by Matteo »
Hola jhon
Tengo asignados dos perfiles ..uno para MTB y otro para carretera...cada vez que vuelvo a montar se enciende la luz parpadeante roja y verde ..que está ocurriendo???
Re: Emparejamiento
You need to do a calibration ride for the profile that is flashing red/green.
Matteo
Re: Emparejamiento
Post by Matteo »
Pero ya hice un recorrido para calibrar!!!!
Tengo ya asignados dos perfiles....pero cada vez q monto en bici de nuevo al encender el PP ,potencia a cero y parpadeo verde y rojo...hay que calibrar cada vez que montas???
Re: Emparejamiento
No, you do not have to calibrate every time.
Please post the profile files (.ibp) for both bikes.
Matteo
Re: Emparejamiento
Post by Matteo »
aqui mando los recorridos a priori con buenos resultados,....te mando lo posteriori los recorrido despues de calibracion..
iBike_01_24_2019_0933_46_km.ibr
mtb
(377.81 KiB) Downloaded 533 times
iBike_01_19_2019_1004_50_km.ibr
road
(418.73 KiB) Downloaded 439 times
Re: Emparejamiento
There are 3 problems:
1) your 1/19 ride has an incorrect value of Crr. I fixed this in the attached profile
2) Your 1/24 Btt ride has incorrect values of wind scaling and CdA. I fixed this in the attached profile
3) Both profiles use the same sensor IDs. From this I assume you are moving your sensors from bike to bike. This is OK, but be aware that you will have to manually switch profiles, using Isaac, for the bike you're riding each day.
Your device might be getting confused because you are using the same IDs for both bikes.
01_19_2019.ibp
(403 Bytes) Downloaded 450 times
BTT.ibp
(508 Bytes) Downloaded 493 times
Matteo
Re: Emparejamiento
Post by Matteo »
Ok gracias
Los sensores son distintos para cada bicicleta.si te sirve de información.
Re: Emparejamiento
For the two ride files you posted the speed and cadence sensor IDs are the same. Are these two ride files from the same bike?
Matteo
Re: Emparejamiento
Post by Matteo »
Nooo uno era de MTB y otro de road con distintos sensores...puede que al estar juntas se haya equivocado.... otra pregunta...los archivos que me as mandado que debo hacer??
Borro los míos antiguos y meto los tuyos al perfil??
Gracias.
Re: Emparejamiento
The two ride files you posted had different weights and wind scaling factors, suggesting they were from different bikes.
However, they had the SAME speed and cadence sensor IDs. This is not good...
I suggest you create new profiles for each bike, then make sure to pair sensors correctly (make sure your bikes are at least 100 feet apart so that you won't accidentally pick-up sensors from your other bike), then do a calibration ride for each.
Matteo
Re: Emparejamiento
Post by Matteo »
Ok muchas gracias
Matteo
Re: Emparejamiento
Post by Matteo »
hola jhon!!!
te mando nueva calibracion de bici de carretera para ver si todo esta bien.
e observado que en descenso y llano los watios son altos???
gracias!!!!
https://velocompforum.com/download/file ... ew&id=5655
iBike_02_16_2019_0934_104_km.ibr
calibarcion road
(773.57 KiB) Downloaded 763 times
Matteo
Re: Emparejamiento
Post by Matteo »
Solo me gustaría saber si está bien calibrado... por favor ayúdame!! gracias
